TPI Miss
Old Feb 19, 2011 | 09:27 AM
rls270's Avatar
TPI Miss
I pulled the jeep out of the garage today and it has a slight miss at any rpm (1500, 3000, 5000). The rpm drops about 200-300 and jumps back up.
I've checked fuel pressure and i did not find any vac leaks.
I did a quick search.
Any help?
Old Feb 19, 2011 | 09:48 AM
herbz28's Avatar
Car: 1987 tpi camaro not sure of motor
Engine: 5.0 tpi
Transmission: 5spd
Axle/Gears: posi track rear end gears unknown
Re: TPI Miss
in my tpi camaro i was having a slight miss and decided to check my cap and rotor and found that my cap had alot of corrosion in it. i cleaned it up with some sand paper and also replaced my spark plug and it now idles great and i barely even notice any miss if there is any. Also get some techron fuel injector cleaner and run that thru your car on a full tank of gas and dont fill up till your almost about empty and that will help as well
stalkier
Dec 6, 2015 11:25 PM
mhatfield 14
Oct 24, 2015 07:48 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
