RPM's drop from 2000 to 500 and engine cuts out.
Old Feb 19, 2011 | 06:59 PM
LoganKello's Avatar
Car: Trans Am GTA
The other day I was driving up a hill and all of the sudden, mid-hill, my rpms dropped from 2000 to 500 and jumped up and down and up and down fairly quickly...The engine was actually cutting out, and then about 15 seconds later the engine backfired. The RPM's continued to bounce for the next 1/2 mile. I then stopped and then started driving again and it drove perfectly fine that day and the days to follow. This exact same thing had happened once before on the SAME road about 3 months earlier...This never seems to happen except when I drive on that hilly road. The only thing I could think is the torque converter (It causes my transmission to shift a little early out of 2nd gear but nothing extreme)
Heres some things to know:
-1991 305 TPI (70,000 original miles) with new fuel lines, fuel tank, fuel pump, new distributor, new fuel filter, new spark plugs and spark plug wires.
Also: I have an exhaust cutout located under the passenger seat and have no catylitic converter and both times my cutout was open...And after I let my car sit for a couple of days (with cutout closed)without starting it, it will run kind of choppy for about 1 minuet until the engine heats up (almost like its burning out moisture).
Any Ideas would help! Thanks a lot guys
Old Feb 19, 2011 | 08:39 PM
LoganKello's Avatar
Car: Trans Am GTA
Re: RPM's drop from 2000 to 500 and engine cuts out.
BUMP
Old Feb 19, 2011 | 08:52 PM
MustangTamer's Avatar
Car: 89 Formula Firebird
Transmission: 700 R4
Axle/Gears: 3:27
Throwing any codes?
Old Feb 19, 2011 | 09:28 PM
LoganKello's Avatar
Car: Trans Am GTA
Not sure what you mean by codes... Im just looking for practical explination as to why this has happened?
Old Feb 20, 2011 | 11:11 AM
LoganKello's Avatar
Car: Trans Am GTA
Anybody?
Old Feb 21, 2011 | 08:40 PM
jibz1985's Avatar
Car: 1987 IROC
Is your check engine light on?
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
LittleFranks
Aug 20, 2015 03:55 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Irocohio
Aug 12, 2015 08:03 AM
