TPI manifold problem
Old Feb 20, 2011 | 07:50 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
i bought this set up last year and had it in storage till this weekend. i took it out to clean it up as i was planning to use it on the convertible. i discovered a hole in the manifold as pictured below. can this be repaired or is the manifold trashed? im wondering if i can repair this with jb weld. it was originally a rusty spot.
its in the back on the passenger side next to the distributor. any ideas or help with this?
Old Feb 20, 2011 | 08:30 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
Re: TPI manifold problem
wow that was from rust?
Old Feb 20, 2011 | 08:37 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
The manifold is made of aluminum and can be welded. That looks like where the rear water cross over would be if there was one. Not a big deal to fix it. Find a local welder who does aluminum.
Old Feb 20, 2011 | 08:45 PM
tonys91rs's Avatar
Car: 91 Camaro RS
its more like corrosion. being aluminum i figure i can get it fixed. i disassembled the whole assembly to clean it and that was the worst of what i found.
Old Feb 21, 2011 | 03:55 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Before going through the trouble of welding up that hole, go over the manifold thoroughly and make sure all the threaded holes are sound, the sealing surfaces are flat, etc.
transaero
Aug 31, 2015 01:14 AM
jbd1969
Aug 17, 2015 07:06 PM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
