Distributor wiring?
Old Feb 23, 2011 | 08:30 AM
daveb8's Avatar
Distributor wiring?
Ok I searched and didn't find what I am looking for. I am doing a tpi in my 64 chevelle. I have the small distributor with external coil. I just want to make sure I get it right. the coil plugs to the distributor simple enough the other pigtail (i believe pink and white wires) is what? The pink I assume is the 12v positive crank and run position. Is the other wire for the tach? Is this correct.
Old Feb 23, 2011 | 05:54 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Distributor wiring?
Correct
Old Feb 23, 2011 | 07:57 PM
daveb8's Avatar
thank you
Caspar
Jun 19, 2016 11:19 PM
g.l.mos
Aug 22, 2015 12:02 AM
355sbcTPI
Aug 19, 2015 04:38 PM
djmarch
Aug 19, 2015 12:07 PM
86IROC112
Aug 17, 2015 07:57 PM
