305 vs 350 TPI: Whats the difference?
Old Mar 6, 2011 | 04:06 PM
lone73's Avatar
I found a 305 TPI off a '92 Camaro for $200. Was thinking of buying it to convert my '73/zz4 to TPI. I think the injectors are too small though.
I currently have a set of SVO Mustang injectors that are about 10 years old.
1. Wondered if they would work in place of stock 24# injectors?
2. Are there any other issues with a 305 TPI that I would need to be concerned about to run it on a ZZ4 motor?
3. Is $200 a decent deal for this particular tpi?
thanks
David
Old Mar 6, 2011 | 04:15 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Re: 305 vs 350 TPI: Whats the difference?
stock 305 TPI's had 19# injectors.. not 24#... 350TPI's had 22# injectors..
what are they including in the $200 price??
Old Mar 6, 2011 | 04:19 PM
lone73's Avatar
oh, sorry. 22#
for $200 it's the complete intake, tb, sensors, rails, injectors but no harness, ecm, dist.
Do you know if my SVO injectors will work?
thanks
David
Old Mar 6, 2011 | 06:22 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Originally Posted by lone73
oh, sorry. 22#
thanks
David
I'm running a set of SVO 19# in my 305, and have a set of 24# in a 350 I'm getting ready to finish.
Old Mar 6, 2011 | 07:58 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
They will "work" but ultimately you want the tune adjusted to accommodate the larger size injectors
Are better deals around
https://www.thirdgen.org/forums/engi...injection.html
Old Mar 6, 2011 | 08:02 PM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
i would say dont even mess with the 305. you can make a ton more power with a carb 305 or even more with a carbed 350. the stock tpi set (305/350) is super constrictive and robs horsepower like a mad man. i had a loner 305 tpi in my Iroc and it had some good power but nothing to write home to mom about.
if you want a tpi set-up i would recomend getting a 350 buying GM performance vortec heads and getting a tpi intake and stealth ram intake. it will up your HP to around 350 with a stock cam.
Old Mar 7, 2011 | 01:27 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
if you want a tpi set-up i would recommend getting a 350
READ what he said.
He is buying the TPI intake off a 305 and putting it on his ZZ4 350 crate engine.
Old Mar 7, 2011 | 06:29 PM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
ah over looked that. stealth ram set-up way better almost the same price
Old Mar 9, 2011 | 09:02 PM
lone73's Avatar
Well I currently have a Street & Performance "Tunnel Ram" intake on it with an older style Accel DFI (dos based interface) harness and computer. I am trying to use the car as a daily driver and now I live 42 miles from work. The setup only gets about 15 mpg. I know I can get into the 20's with a stock TPI.
Maybe I should try to continue to use my tunnel ram and hook it up to a stock 7730 computer and harness. I don't know if it would get decent mileage or not since the stock chip is tuned for the long tube TPI intake.
Whaddya' think ??
thanks
David
Old Mar 10, 2011 | 08:11 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
what you lose in top end horsepower you gain a touch on the torque, plus maybe hes looking for better driveability....that would be a reason for me to go to fuel injection
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
