need TPI TB, which stock one to get?
Old Mar 7, 2011 | 03:53 AM
tmoble's Avatar
Hi, Have a 92 TPI setup off a 350 Camaro. It's going on a 327 in a 57 Chevy pickup with a Mega-Squirt computer. There was no throttle body with the TPI when I got it. I want to run a stock one, would like to keep it as simple as possible. Which TB should I look for? I have a 200-4R OD tranny to put in so I need the right linkage setup. Is that style with the wrap-around cable cable deal any good or just get the older style with the 2 pegs for cables with eyelets on the ends?
What's the make-model-year deal on this? look for one from a 92 Camaro/Firebird?
Old Mar 7, 2011 | 06:43 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: need TPI TB, which stock one to get?
Makes no difference; all TPI TB's have the mount for TV cable.
Early type is easiest for a retro fit because it will take a common carb type cable end on the stud whereas the later wrap around style requires that particular cable.
gta90
Sep 15, 2015 04:00 PM
jbd1969
Aug 17, 2015 07:06 PM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
marcusaw
Aug 10, 2015 08:13 AM
