High start Idle
Old Mar 10, 2011 | 07:29 PM
Marv02's Avatar
Car: 1986 Vett, 2001 Expedition
Engine: 383SBC 435 H/P, 500 TQ
Axle/Gears: 307
High start Idle
Sometimes after the car is up to operatring temps and shut the motor off then restart it latter the motor still at operating temp it will rev to 3500 to 4500 RPM's then go down to 1000 RPM after a couple seconds WHY.
I dont have any vacume leaks the base Idle is set at 450 RPM's the Normal timiming set a 6 advance.
Most of the time in gear the Idle is at 650 to 700 RPM In gear it's a uto trans.
The motor not stock it a mild build it has a chip for the mods.
I dont remember the motor doing this before the rebuild from stock motor.
It will also surge when slowing down moving foward to a idle 650/700 Rpm's to 1000 Rpm's I think it's the TQ convertor the place that rebuild the trans screwed it up I still working getting anouther trans.
Old Mar 11, 2011 | 12:31 AM
xxpotandaxx's Avatar
Car: 1992 Camaro z28
Engine: 5.0 TPI
Transmission: 5 Speed Manual t5
Re: High start Idle
i have the same issue
Old Mar 11, 2011 | 10:52 PM
Marv02's Avatar
Axle/Gears: 307
Re: High start Idle
I had a Spare MAF I swaped it out and adjusted the Volt of the TPS from .55 to .539
It runs much better I dont Idle as high any more during start up.
Orr89RocZ
Apr 25, 2016 08:28 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
