vortec conv want start
Old Mar 13, 2011 | 03:16 PM
87g92iroc's Avatar
need some help, have a 87 iroc tpi did a vortec conversion had the car apart for about 9 months to paint engine compartment. built a 5.7l engine with vortec heads edlebrock tpi intake purchased injectors from injector connection bocsh design 3 24 lbs engine is in wired complete done ready to go but will no start.
heres what what i have checked
injectors test at .015 oms check them all same reading
injectors click with a jumper and a 9v battery
rented a noid light has pulse when you turn over the engine
has fuel presure 40lbs max when i jumped the fuel pump and jumpes to about 39 when the key is turned on and the new relay clicks.
replaced the coil with one i know works came with the car
igninition has spark from about 1/4'' away from headers using a screw driver.
tps is set at 0.54 with wot of 4.30 or so.
when it turns over sounds like it wants to start if i spray brake cleaner or just recently start fluid it sound more like it wants to start but nothing.
i purchased this car running so i know the ecm is good
Old Mar 13, 2011 | 06:45 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: vortec conv want start
Originally Posted by 87g92iroc
built a 5.7l engine
Is the valve timing correct?
Is dist timing correct
Any codes showing?
Old Mar 14, 2011 | 08:52 AM
87g92iroc's Avatar
time chain is set striaght up mark to mark on sprockets i am sure double checked that before installing timing cover.
dist timing wires are correct double checked that yesterday 18436572
timing mark at tdc both vales at cyl #1 closed rocker loose rotor pointing to #1 cylinder roter cap and wire at #1 cylinder checked clockwise rotation wires correct 18436572?
maybe the spark is not good enough i am thinking of replacing the ignition module inside the dist and a new battery? what do you think
Old Mar 14, 2011 | 03:50 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
are your valves adjusted right?
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
bamaboy0323
Sep 3, 2015 06:07 AM
