No spark after Intake rebuild HELP!
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Rebuilt the whole TPI intake, had it hot tanked, painted, reassembled with new gaskets. Every connector was labelled while being disassembled..
We have 12V to the coil pink wire. We are not getting a spark, I believe he painted the coil, but 10,000V should theoretically jump through that, and we also tried jumping a ground from the coil directly to the body to no avail.
It has me totally stumped, and I've worked on Thirdgens for over 5 years...
Engine: 2004 LQ4
Re: No spark after Intake rebuild HELP!
Haha what a goof..
The air temp sensor under the plenum has the exact same connector that goes into the distributor.. Fired up just fine.
1992 Trans Am
May 10, 2023 07:19 PM
