help with wiring on a tpi
Old Mar 16, 2011 | 11:36 PM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
i have '89 350 tpi and its in a '86 trans-am i sold my origall harness with the old motor and i found a '85 trans-am tpi harness at the jukyard I'm having trouble with the ecm the '89 350 tpi came with the reason is vats now i could splice wires to make it work with the vats on other modules needed to run the engine but my friend has a parts car a '91 trans-am that originally came tpi but i know it was for speed density could it ne possible to use the harness of the '91 on my '89 ecm and follow the wire of the speed density and remove it and put in its place the maf wire or wires on the harness
Old Mar 17, 2011 | 06:59 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: help with wiring on a tpi
Have to do reverse of this. Lots of work
http://www.s10wildside.com/wildside/ecmandtuning.htm
Easier to get a SD '730 computer to go with the 91 harness and run SD.
Many upgrade from MAF to SD because it involves less wiring ; no burn off relays , MAF sensor or spark control module
The 89 engine won't know any different ,
Caspar
Jun 19, 2016 11:19 PM
jbd1969
Aug 17, 2015 07:06 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
