91 z28 Rough Idle Please help
Old Mar 18, 2011 | 05:04 PM
Annihilated911's Avatar
Car: 91 z28
Engine: 5.7 350 TPI '91
Transmission: World class T-5
Axle/Gears: Stock ??
91 z28 350 TPI .. Has rough idle cold or warm. Constantly revs back and forth from 1100rpm-2000 RPM. Im not getting any check engine lights/codes which makes me not think THrottle position sensor or IAC valve ? Any ideas please help!
Old Mar 23, 2011 | 11:30 PM
skibum2100's Avatar
Car: 1988 GTA
Engine: 5.7 TPI w/ Bosch III's
Axle/Gears: 3.27 Borg Warner 9 bolt
Re: 91 z28 Rough Idle Please help
Start with easy things to check...like a vacuum leak. If you have a voltmeter you could measure the top two wires of the Throttle Position Sensor...it should be .54V at idle.
Did your car ever run right or did you buy it like this?
Old Mar 24, 2011 | 08:07 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
could be IAC, TPS, a vac leak, a bad injector maybe too.
start with the easy stuff and work your way up
bamaboy0323
Sep 3, 2015 06:07 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Bradsaundry
Aug 12, 2015 12:34 AM
