Alternator mounting ???
Old Mar 22, 2011 | 01:15 PM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
I put new heads and stealth intake on my car and had removed the smog pump a while back. Now that im mounting my alternator I do not know what to bolt the alternator to on the motor. Does anyone have pics of their alternators on the passenger side of the car with no smog pump?
Old Mar 22, 2011 | 08:00 PM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
Re: Alternator mounting ???
hey i will try to remember to take my camera tomorrow and take a pic for you
Old Mar 22, 2011 | 10:19 PM
Transmission: 700r
Thank you I will really appreciate that. The car is so close to starting and this is the only main issue I have had.
Old Mar 23, 2011 | 09:45 AM
hope this helps i took two one with my alt out and one in if you need a diff shot lemme know
Attached Thumbnails Alternator mounting ???-car-001.jpg   Alternator mounting ???-car-002.jpg
Old Mar 23, 2011 | 10:28 AM
Transmission: 700r
Thanks! I going to try that today and see how it works. Do you know what size bolts are needed by any chance?
Old Mar 23, 2011 | 10:42 AM
i don't sorry
Old Mar 23, 2011 | 11:48 AM
are you missing bolts? i have a spare lower bolt thats the long one if you wanted to cover shipping cost i will send it to you if you need it
Old Mar 23, 2011 | 01:31 PM
Transmission: 700r
Im good on bolts I believe I just need a smaller bolt to since i dont have the smog pump.
Old Mar 23, 2011 | 03:01 PM
you should only require the lower bolt and the upper bolt be sure you did not mix up the bolt from the smog pump and the alternator. but i have no smog pump either i removed it and i didn't have to change any of the mounting hardware for the alternator.
Old Mar 24, 2011 | 04:10 PM
Transmission: 700r
Do you have the stealth ram?
Old Mar 24, 2011 | 04:41 PM
uh no sir i do not believe so
Old Mar 24, 2011 | 06:40 PM
Transmission: 700r
Damn I dont think this will work then because I dont have a bracket for alt with the new intake.
Old Mar 24, 2011 | 06:52 PM
u need the upper bracket? whats the issue is the mounting hole in the wrong place or different? if u just need a stock bracket u can find it at the bone yard if you need a different style bracket try the earlier model bracket i might be able to help you more if you post some pics
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Sep 12, 2015 12:33 AM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
