injectors
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: injectors
If you can't help him with his question why post a comment like that about his grammar.
Re: injectors
Check to see if you have pressure at the rail, also check your fuses. Look to see if you have power to the injectors. I doubt there is anything wrong with them. Pump, filter I agree to look at them also. Good luck I hope this helps
thejimsterz28
09-15-2015 04:37 PM
