new to the TPI, need some HP Help
Old Apr 9, 2011 | 02:38 PM
Pezcore67's Avatar
Hi, i am new here but i recently bought a 1980 camaro that has a tpi 355 in it. The car has full exhaust true dual, long tube headers and no cats. As far i know it is running a zz9 cam with ported 083 cast iron cylinders heads. The TPI manifold is stock, i was wondering what would be my best move from here to gets some decent HP out of this bad boy? Also, it has custom wiring harness from TPIS, i am a little stuck on deciding if i should scrap the heads and intake or just the intake and i am thinking about some 1.6 rockers as well.
Old Apr 10, 2011 | 07:20 AM
Pezcore67's Avatar
Re: new to the TPI, need some HP Help
anybody? dont you guys deal with this engine all the time?
Old Apr 10, 2011 | 06:34 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
If you are dealing with stock TPI no amount of engine/exh changes will do much until you upgrade the intake
Do a search in TPI dept
Many previous post on TPI mods
Old Apr 12, 2011 | 01:26 PM
myzblubyu's Avatar
Car: 1990 Iroc, 1984 Buick Regal
Engine: 5.7, ZZ4 crate w/FIRST injection
Transmission: 700r4, 700r4
Axle/Gears: 3.73, 4.11
HSR (holley stealth ram) or a TPIS mini-ram would be your best bet... It's far cheaper than fully porting your plenum, buying ported SLP runners and getting a ported intake or buying a TPIS big mouth intake... enjoy
Old Apr 12, 2011 | 04:46 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
aluminum lung...
Old Apr 18, 2011 | 05:08 AM
bobbyk3lly's Avatar
Car: 1994 Camaro Z28 B4C T-tops,
Engine: LT1 350 5.7L 116K
Transmission: 4L60E (being rebuilt)
Axle/Gears: 3.23 Posi
yeah theres not much we can do with a Stock TPI,
Old Apr 18, 2011 | 05:09 AM
bobbyk3lly's Avatar
but they are easy to mod,
Old Apr 18, 2011 | 05:10 AM
bobbyk3lly's Avatar
and when you do mod them you can get alot of HP without having to change too too much about them, simple bolt ons do alot for these motors,
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
