Fuel problems
Old Apr 15, 2011 | 07:07 PM
bigal011's Avatar
Fuel problems
My 86 iroc wont start. I can spray a little starting fluid in the intake and it will fire long enough to burn it off and then will die. To me, this sounds like a fuel pump. When you turn the key on you can hear the fuel pump kick on.
Any idea???
Old Apr 15, 2011 | 10:26 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Fuel problems
1) Change fuel filter - driver side in front of rear wheel.
2) Test the pressure at the fuel rail. You can rent for "free" a fuel pressure tester at any auto parts store. There is a Schraeder valve on the pass side fuel rail (liike like a tire valve) - screw tester on there, and test the pressure.
The fuel pump has a rubber hose that attaches it to the hard line in the tank - they rot away over time being in the gasoline all the time.
I'm guessing your filter is clogged, or that rubber hose in the gas tank is toast.
Old Apr 16, 2011 | 04:31 AM
bigal011's Avatar
Re: Fuel problems
Ive already changed the fuel filter,and I will check the hose in the tank. Thanks for your input.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
