What valve springs
Old Apr 16, 2011 | 07:32 PM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
What valve springs
Hey guys,
I have a 350 tpi, fully forged bottom end, Home ported and gasket matched 083, lt4 hot cam, and stock rockers
I bought the lt4 hot cam valve springs, but they wont fit in the heads.
What valve springs do I need for this cam?
Where is the cheapest place to get a new chip burnt for my car?
Old Apr 17, 2011 | 06:24 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: What valve springs
You don't state what size spring ( dia ) you need to clear
Hot cam with 1.5 rockers is .495 lift so you need a spring that will fit your heads that has similar spec
to the hot cam spring
Min specs
.500 lift
100lb on the seat
330 lb spring rate
Old Apr 17, 2011 | 10:03 PM
Curious_George's Avatar
Car: '87 IROC, '92 & 99 Corvette Vert.
Engine: L98, LT1, LS1
Transmission: L98 = 700R4
Axle/Gears: L98 = 3.23 G92
I used "Z-28" springs in my recent build and they appear to be OK.
http://cgi.ebay.com/ebaymotors/HP-Z2...Q5fAccessories
CG
pjsparts
Oct 29, 2025 06:39 PM
crzycamaro86
Sep 12, 2015 05:51 PM
ericjon262
Sep 11, 2015 06:07 PM
lakeffect2
Sep 7, 2015 03:52 PM
