1.6 roller rockers
Old Apr 19, 2011 | 10:23 AM
myzblubyu's Avatar
Car: 1990 Iroc, 1984 Buick Regal
Engine: 5.7, ZZ4 crate w/FIRST injection
Transmission: 700r4, 700r4
Axle/Gears: 3.73, 4.11
1.6 roller rockers
I have a 1990 IROC with the L98, headers and 3" exhaust. This weekend I'm putting a HSR with 24lb injectors and while I had everthing off I want to install some 1.6 roller rockers that I have left over from my LT1 build. The head is stock along with the factory cam. Will the 1.6 RR work with the stock springs? Should I wait until later this summer when I plan on installing the new heads along with an LT4 hotcam that I have laying around? Will I have to reprogram the factory prom now? I wanted to wait and program the prom after the head and cam install later this year. Any comments will be useful and thanks in advance.
Old May 12, 2011 | 09:34 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Re: 1.6 roller rockers
you have probly already done this, judging by the date of the post, but i would not waste your time with those 1.6's until you change the cam. you might be ok with the stock cam, but i don't know that for sure, as far as clearance for the rods goes... i know that when i put that same cam in mine, the heads required some machining to accomodate the higher lift...
Old May 17, 2011 | 04:03 PM
Eagle223usa's Avatar
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
My pushrods were binding in the slot where they come through the heads with the 1.6's. I used a Louis tool to clearence the head slots.
Old May 17, 2011 | 04:49 PM
whitecomet's Avatar
Car: 1987 Pontiac Firebird formula 350
Engine: sbc 355 tpi
Axle/Gears: 3.27 posi 9 bolt b/w
id wait til u get the cam in as well. i have roller tip (full roller wouldnt fit under my center bolt valve cover) rocker 1.6 all the way around i got the self aligning ones wit a mild cam wit stock size 22lbs injectors an my car runs fine with that set up not much difference in power but thats my 2 cents
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
