another code 22
Old Apr 22, 2011 | 10:59 PM
xdevenx's Avatar
Car: '89 Formula
Engine: T.P.I. 305
Transmission: Borg Warner T-5
Axle/Gears: Borg Warner 9 bolt - 3.70 posi
another code 22
so i've replaced my TPS because of issues ive had with it, plus a code 22. i've checked voltage, got 5v. tps is adjusted to .54, and reads .54 at the ecm. Why would i still have a code 22 if the computer is reading the correct voltage?
Old Apr 23, 2011 | 12:06 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: another code 22
did you dump the memory from the ecm by unpluging the battery for 30 sec. after you replaced the tps
Old Apr 23, 2011 | 07:51 AM
xdevenx's Avatar
Car: '89 Formula
Engine: T.P.I. 305
Re: another code 22
no, haven't done that yet, tried clearing the code with the scanner a few times, memory dump is next.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
