gas problem for a 88 camaro 5.7
Old Apr 25, 2011 | 09:48 PM
cruzplcs's Avatar
Car: 1988 Chevy Camaros
Engine: 350 5.7
Axle/Gears: Stock rearend
Ok heres the problem when i turn the car on it takes time and I can smell gas vapor big time coming from the engine and when im the freeway The vehicle engine runs rough and often stumbles and sputters? what could be the problem
Old Apr 25, 2011 | 09:55 PM
nickhil2003's Avatar
Car: 1982 trans am
Transmission: 4 speed
Axle/Gears: 3.08
Re: gas problem for a 88 camaro 5.7
check all the fuel lines going to the rail and injectors, i would also check the fuel preasure
Old Apr 25, 2011 | 10:06 PM
Pab's's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI with zz4 heads
Axle/Gears: 9 bolt BW
I have the same problem I checked my fuel line's but no cracks or leaks wtf
Old May 1, 2011 | 10:05 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
What about your carbon canister? Smell fuel there? Also , check the check valve around your gas tank. It is a small white plastic valve. Check your spark plugs to see if you have leaking injectors. You will smell and see fuel on them.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mustangman65_79
Sep 1, 2015 03:51 PM
92camaroJoe
Aug 13, 2015 06:07 AM
