Removing smog pupm set up on my GTA???
Old Dec 28, 2003 | 04:04 PM
TPI86TA's Avatar
Car: 88 GTA
Removing smog pump set up on my GTA???
I see my 88 GTA still has the smog pump and all the emissions stuff that goes with the pump.Is there any horse power gain by removing it and if so how do you remove it or where can you get it removed.If the smog equipment ever goes bad what kind of problems can it cause for your car.Could it cause any problems like you car smoking out of the exhaust?
Old Dec 28, 2003 | 07:07 PM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
https://www.thirdgen.org/newdesign/t...rpentine.shtml
Old Dec 29, 2003 | 09:00 AM
The gta master's Avatar
Car: Pontiac Transam Gta
Engine: L98 350
Transmission: Th700r4
I removed my smog pump last week the belt setup did not work the belt was still too short after rerooting i had to get a longer belt the diagram looked like it would work but was actually wrong using stock belt with air con still.
Old Dec 29, 2003 | 09:53 AM
Car: 92Z28
Transmission: A4
Mine fit fine using the diagram and recommended belt. Do you have any underdrive pulleys?
Old Dec 29, 2003 | 10:10 AM
Steve89GTA's Avatar
Mine did not fit right according to the article. I had to get a longer belt as well...
Old Dec 29, 2003 | 07:58 PM
TPI86TA's Avatar
Car: 88 GTA
so could a bad smog set up cause your car to smoke,does anyone know???Thanks.....Al in NJ
Old Dec 30, 2003 | 02:57 PM
Car: 92Z28
Transmission: A4
I don't think a smog pump would make it smoke. I suppose it could smoke if it were losing a bearing, for a short time, but it would soon lock up and stop turning.
Old Dec 30, 2003 | 03:01 PM
Steve89GTA's Avatar
When my bearings went on the pump, it sounded like a busted valve train. Scared the **** outta me. I threw that thing in the trash 2 years ago and haven't looked back..
Old Apr 28, 2011 | 09:59 PM
88 AB GTA's Avatar
Re: Removing smog pupm set up on my GTA???
Hello, I'm planning to put some headers on my 5.7 88 GTA, I just want to know if there is any problem if I don't put the little pipes on the manifolds for the smog. or what would be the right headers to use.
Old Apr 28, 2011 | 10:24 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Removal of the smog pump depends on your local/county/state inspection and emission requirements.
There is no hp gain.
There's nothing a smog pump can do to make excess exhaust - but a seized bearing would make the belt smoke and burn through.
Old Apr 28, 2011 | 11:36 PM
DoWork2day's Avatar
Car: 1989 IROC 406 SBC (2012 Fusion)
Engine: 406 Chevy-World Sportsman heads
Transmission: 700R4 B&M, Redline clutches, 2800
Axle/Gears: Australian 9 bolt,I think 3.73
The smog pump is drag on the engine, it's going to free up a few horsepower. It's not dramatic but it adds up, and I'm also removing the AC. I have a 406 in the Iroc, been raining all week couldn't go try it out. More time for tuning I say!
Old Apr 29, 2011 | 06:39 PM
DJK90IrocZ's Avatar
Car: 90 Camaro IROCZ
Engine: 5.7L TPI
Transmission: Auto 4 speed
If you remove the AIR pump and the pipes, will you have any issues with the cats running hotter since there is no air being forced in them.....and will you have a SES light come on?
Old Apr 29, 2011 | 07:17 PM
rob2000gt's Avatar
Car: 91 Trans Am GTA
Engine: Tpi 5.7
Axle/Gears: 3:23
No issues at all with removing them and I did the pump delete and never had ses light come on even after a 6 hour trip but make sure you dont have emission testing
Old Apr 29, 2011 | 08:48 PM
DJK90IrocZ's Avatar
Engine: 5.7L TPI
Rob,
I heard something here on TG that when you dont have AIR going to your cats and manifolds that the ECM doesnt send as much fuel to the injectors which makes the car run slightly lean....If it runs lean, then you dont have as much power...correct?
No emission testing in Maryland IF the car is 20 years old AND you register it as a Historic car......which I have done.
Old Apr 29, 2011 | 11:08 PM
DoWork2day's Avatar
The bad thing about Michigan is the rust and the bumpy roads.
The good thing is the abundance of cars for sale, and the best part:
NO EMISSIONS TESTING. It's a must to remove the catalytic converters.
Old Apr 29, 2011 | 11:09 PM
DoWork2day's Avatar
Actually, it's not "removing" cats on a third gen you must be ADDING a catalytic converter every time you do exhaust. Surely the exhaust is not original on a 1980's car?
Old May 1, 2011 | 07:07 AM
rob2000gt's Avatar
Engine: Tpi 5.7
Axle/Gears: 3:23
Originally Posted by DJK90IrocZ
Rob,
From my experience after I did some upgrading I noticed more power but worse gas mileage. I dont think I am running lean but I dont know for sure all I know is my car is fairly quick now
Old May 1, 2011 | 11:01 AM
DJK90IrocZ's Avatar
Engine: 5.7L TPI
That sounds right....more fuel in the cylinder makes more power and less fuel economy. Then again....who cares about fuel economy with these 20 year old muscle cars....hahaha.
Did you have your AIR hooked up or just capped off the cat tube?
Old May 1, 2011 | 12:26 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
The only way it should affect your fuel/air ratio is if your diverter valve was bad. Mine was, so it always let some air into the exhaust manifolds. Being before the oxygen sensor, made the car think it was running lean so the computer adjusted it to be too rich.
Old May 1, 2011 | 01:50 PM
rob2000gt's Avatar
Engine: Tpi 5.7
Axle/Gears: 3:23
I have headers and removed the cats but when the exhaust was removed for the headers noticed the cats were empty anyways no point to have empty cats. I did like my good gas mileage because my car is a daily driver but I fixed the issue, I moved a block away from work I am doing my part in not giving the oil companies very much of my money lol
transaero
Aug 31, 2015 01:14 AM
Street Lethal
Aug 14, 2015 08:25 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
