fuel problems HELP!!!
Old Apr 29, 2011 | 10:13 PM
my89camaro's Avatar
Car: 1989 Iroc-z camaro
Engine: 305ci HO
Transmission: manual 5speed
Axle/Gears: Borg Warner w/ 3.08 gears
My 89 is running wierd it sounds like it's miss fireing and is hard to start. i disconected the mass air flow sensor and most of the problems went away. It starts easier and quicker with it unpluged. I was thinking about replacing the MAS but i want to make sure there's nothing wrong with the relay or solenoid. Any thoughts appreciated.
Old May 1, 2011 | 03:09 AM
Blazer79's Avatar
Car: 1986 Iroc-Z
Engine: Stock 305 TPI MAF w 148,000 mi.
Re: fuel problems HELP!!!
Disconnecting the MAF does not guarantee that the problem is there. It simply makes your ECM go into limp home mode, so it ignores all the sensors and uses a preset mixture. Do you have trobule codes? Have you done any recent changes to the engine that caused this?
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
