Dyiing at Idle
Old May 3, 2011 | 07:42 AM
Turbok9's Avatar
Car: 91 Z28 Coupe / 92 RS Vert
Engine: L31 350, HSR / L31350 Carb
Transmission: 700R4 / 700R4
Dyiing at Idle
Strangeness.
Our 91 Z28 has been running decent, except everytime the woman drives it, she hits something or something breaks.... Which is expected, as she also has a 'black' thumb as a gardener, and everything she touches seems to wither and die... I think she's posessed .
Anyhoo, the last week the old gal (the car) has started dying at idle sometimes... at first I just thought it was when she was hot, but yesterday it happened first thing in the AM. If I 'cycle' the ignition (restart, restart, restart) she'll usually start running normal, idles at 500 +/-. Even when she won't idle she runs nice as long as you give just a wee throttle, and is drivable and powerful if you left foot brake well.
She's a TPI 305, mildly cammed, standard timing. Just cleaned and resealed the EGR, checked voltage at TPS (OK) and the IAC seems to be functioning properly. Manifold vacuum steady at 20-21. Having a real bear of a time figuring this one out... If something is going to break, just break! This intermittent stuff messes with my head, .
Hoping someone has seen something like this and has some ideas! TIA!
Old May 4, 2011 | 12:21 PM
Turbok9's Avatar
Re: Dyiing at Idle
Nobody? Nada? No thoughts?
Old May 4, 2011 | 01:06 PM
9340Ruby's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 pos
Re: Dyiing at Idle
How many miles on it? Could be the fuel pump going out. Just a thought.
Old May 5, 2011 | 04:02 PM
Turbok9's Avatar
Re: Dyiing at Idle
Checked fuel pressure and it was good... but I suppose that doesn't mean it's good all the time... And when I checked it, she was in a good mood. I suppose I'll check it next time it doesn't want to idle and see what's what.
Old May 5, 2011 | 06:46 PM
9340Ruby's Avatar
Re: Dyiing at Idle
I would definitely check the pressure when it acts up or when it has ran for a while(hot). Hope all works out for ya.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
