Keeps throwing a code and bogging???
Old May 6, 2011 | 08:14 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
The car will run great and fine and then randomly it will trough a code and bog down. Not want to really go without almost flooring it. Then it will go away and run fine again?
Old May 6, 2011 | 08:25 PM
Axle/Gears: G92
Re: Keeps throwing a code and bogging???
Also it only happens at low speeds or stops
Old May 19, 2011 | 11:01 PM
darkness878's Avatar
Car: 1987 iroc z camaro
Transmission: 700 r4
Axle/Gears: no idea
mine is doing the same thing rpms all over the place and running like ****
Old May 20, 2011 | 01:26 AM
ahankins32984's Avatar
Car: 1986 Camaro Z28
Engine: 5.0 305 TPI
Axle/Gears: posi 3.73
hows is you fuel pump
Old May 20, 2011 | 06:34 AM
Axle/Gears: no idea
i didnt even think of that yet
Old May 20, 2011 | 07:37 AM
karl's-92'-z28's Avatar
Car: Too many cars
Fuel pump,fuel regulator, fuel filter
Old May 21, 2011 | 10:20 AM
Axle/Gears: G92
All should be fine, it doesn't happen all the time, just sometimes. Maybe it is idling to low, it idles around the 600 range, only does this when warmed up. Could it be timing?
Old May 21, 2011 | 02:06 PM
Car: Too many cars
Check your IAC?
Old May 21, 2011 | 02:26 PM
Axle/Gears: G92
Check your IAC?
I didn't even think of that, I'm gonna check the code tomorrow and replace it just in case cause I'm driving it a hour away next weekend.
Old May 22, 2011 | 04:22 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Possible that your distributor is starting to go.
Old May 22, 2011 | 04:33 PM
Axle/Gears: G92
Hmmm what that cause it to throw a code? I notice that it also will stumble alittle and kind of hunt for a idle.
Old May 22, 2011 | 05:16 PM
Car: Too many cars
Checked you MAF & MAF sensor?
Old May 22, 2011 | 05:34 PM
Axle/Gears: G92
It's speed density..
Old May 22, 2011 | 11:52 PM
Car: Too many cars
Oh its the 305, did you check the IAC?
Old May 22, 2011 | 11:55 PM
Axle/Gears: G92
It's a 350, no I havent
Old May 23, 2011 | 06:45 AM
Mr Froman's Avatar
Pull a code so we can narrow it down some
Old May 23, 2011 | 11:40 AM
Axle/Gears: G92
Here is a vid, what code is this
http://www.youtube.com/watch?v=c3Fyn...e_gdata_player
Old May 23, 2011 | 01:50 PM
Mr Froman's Avatar
This isn't a fault code. Code 12 when grounding the two terminals basically tells you that your car's on board diagnostics are functional.
Old May 23, 2011 | 09:56 PM
Axle/Gears: G92
http://www.youtube.com/watch?v=di7D4...e_gdata_player
Here is the full vid I took. Sorry that one got cut off somehow
Old May 23, 2011 | 10:27 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Codes 32-EGR failure, 42-EST system failure, 43-ESC Knock sensor failure. The EST(electronic timing control) or the knock sensor circuit, either one, could cause the bogging. Check the knock sensor connector for damage or poor connection. Look at the distributor internals for corrosion. Check connections at the dist. Check ECM grounds at the rear of the cyl. heads.
Old May 23, 2011 | 10:39 PM
Axle/Gears: G92
could the timing being off cause that code? also what do I need to do about the egr? should I fix it? If I delete it will it throw the code? I need to fix this by fri cause I am driving it a hour away and don't want any issues.
Old May 24, 2011 | 01:40 AM
Car: Too many cars
Check your TPS, someone just posted something about it.
Old May 24, 2011 | 07:44 AM
Axle/Gears: G92
How do I check it? could it cause this?
Old May 24, 2011 | 07:56 AM
Car: Too many cars
https://www.thirdgen.org/forums/tech...dle+adjustment
Old May 25, 2011 | 09:07 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
An internal fault in the dist could cause this type of issue. Mose likely though, it is wiring. Could also be a broken knock sensor that is making intermittent contact. This is where depth of diagnostic skill comes in along with a labscope.
If the knock sensor circuit (ESC) has an intermittent open or short, the ESC module will pull 18 degrees of timing. This will kill power severely. A fault in the dist is more likely to shut the motor down.
Old May 25, 2011 | 10:07 PM
Axle/Gears: G92
I'm gonna change the ignition module and knock sensor and hopefully that fixes it
Old May 26, 2011 | 01:54 PM
Mr Froman's Avatar
Does your tach jump?
Old May 28, 2011 | 07:50 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
I really don't support swapping parts without verifying a failure. You don't really know yet what is causing the problem. If you have spare, known good, parts on hand that's one thing. But buying parts without verifying the cause of your issue will get expensive quick and even more frustrating. The knock sensor is easy to test with a scan tool and a long 3/8" extension. While watching "Knock Retard" on datastream, use the extension to tap on the block close to the sensor. You should see knock retard go as high as 18degrees. If not, you have an ESC problem. The nature of your problem is obviously intermittent which likely makes it a wiring problem, such as a loose connection. It may be a loose ground at the rear of one of the cylinder heads or a bad connection at the knock sensor. As I said before, it could be a bad knock sensor too.
Old Jun 8, 2011 | 06:04 AM
B Rhodes's Avatar
Car: 91 B4C
strange just did a bunch of work on my 91 camaro 350 tpi and threw the same 3 codes and started idling a little funny. Ill hopefully get it sorted soon and post any info
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Grant2k
Apr 4, 2016 08:21 AM
BumpaD82
Feb 26, 2016 02:57 PM
86IROC112
Nov 27, 2015 09:54 AM
