will a disconnected egr suffocate my engine?
Old May 9, 2011 | 02:39 PM
peicheff's Avatar
Car: camaro iroc-z
Engine: 305 tpi
Transmission: 5 speed
after i got my intake manifold gasket redone my car has been stalling at every stop light and now just when i go from in gear to neutral or clutch disengaged. when i got my car back from the shop i noticed that my egr connector was no longer attatched, could this be my problem?
Old May 9, 2011 | 06:16 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: will a disconnected egr suffocate my engine?
if the egr was disconnected while it was stuck open, it would give you a rough idle and possibly stall at idle (really depends how open it was) but youd notice this problem immediately after you started the car, if your car is stalling after its been warmed up, id say check elsewhere, possibly ignition coil, ignition module, or IACV
Ghettobird52
Jul 5, 2024 11:18 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mdtoren
Aug 23, 2015 12:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
