Cam help for 4x4 TPI
Old May 10, 2011 | 01:09 AM
skuanto's Avatar
Car: 1988 Iroc Z
Engine: 5.7 TPI
Axle/Gears: Stock gears.. disk posi
Wassup guys
Sooooooo after a lot of research, asking questions, getting answers and opinions I am now ready to swap my 1988 l98 8 engine code TPI engine from my old iroc into my 85 k5 blazer and have decided to just go with a more aggressive cam.
I am going to be using the truck for My 14 hour trips to Mexico and racing up sand hills, occasional trips to pismo and racing against my friends trucks. So I'm looking to get the most out of all my RPM ranges especially bottom end but I don't wanna go to take my heads to the machine shop. So biggest cam without modifying heads.
Any opinions and input is great I will b starting this project in about a month I'm just trying to get everything ready
Thanks in advance!
Old May 31, 2011 | 01:26 PM
ervin's Avatar
Re: Cam help for 4x4 TPI
HAS this engine still have the TPI manifold? If so question answered.Stick with a cam suited for the RPM of the manifold,no higher than 5000 RPM.RULE of thumb most blower,nitros,and 4X4 cams run lobe sep. angle at 114 degrees.Good idle and torque.If you need reasons ,read up on a topic called pulse res.
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
Sanjay
Aug 12, 2015 03:41 PM
