getting frustrated
Old May 31, 2011 | 04:51 PM
fallen0kashi's Avatar
Car: 89 z-28
Engine: 388
Axle/Gears: 3:42
getting frustrated
Ok, I have an 89 iroc with a 350. I have had this problem with it for about a year, when I come to a stop on a hot day my car with either stall or it will try to stall a.d catch itself. I have had many people look at this and no one can give me an answer why. I have changed the maf, tps, iac, fuel regulater, cleaned the throttle body, new plus and wires and new fuel pump o and the ecm. The car is not stock its bored .40 over and has a high cam. Can someone help me please
Old May 31, 2011 | 04:52 PM
Car: 89 z-28
Engine: 388
Axle/Gears: 3:42
Re: getting frustrated
And I forgot checked for vacuum leaks
Old May 31, 2011 | 05:21 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
probably need a tune. get it dyno tuned or get a get prom from (i think) pcm4less. are you sure you even have a good combo with that cam? do you even know what type of cam? could even need a stall converter. if you have some type of thumper cam with a factory converter, it could be bogging down your engine when comming to complete stops. does it push, or hop around at stop lights?
Old May 31, 2011 | 05:22 PM
Engine: 383 hsr
and do you have a check engine light?
Old May 31, 2011 | 06:12 PM
Car: 89 z-28
Engine: 388
Axle/Gears: 3:42
No the service engine not on. I have no idea what kind of cam I have asked the previous owner abou the problem and he is nice but has always been less than helpfull. When I stop it kinda lunges forward. It seems to always have a really rough idle I kno the high cam will got it that but it seems rougher than it should be. I have been looking for someone with a dyno around here but I can't find one
gta892000
Aug 11, 2019 11:16 AM
1992CamaroGirl
Dec 25, 2017 08:45 PM
RedLeader289
Sep 23, 2015 06:50 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
