Looking to replace my old TPI throttle body, whats the better choice?
Old May 12, 2011 | 05:26 PM
TX T/A's Avatar
Car: 1992 Trans Am Conv.
Installing rebuilt engine and don't want to use the old TB on my 350 TPI. I will use stock plenum so what's the best replacement for the money?
Old May 12, 2011 | 07:14 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: Looking to replace my old TPI throttle body, whats the better choice?
Stay with the stock 48mm or an aftermarket 52mm at the most. Ebay has some used and rebuilt ones; http://motors.shop.ebay.com/i.html?_...e+body&_sacat= BBK and HOLLEY are into aftermarket. Some people would say to get a 58mm, but that's a pure waste of money. A stock 48mm will out flow any stock intake.
Old May 15, 2011 | 05:44 AM
megtom2's Avatar
Car: 1989 Pontiac Formula 350
Engine: 350 tpi
Transmission: 700
Check out the ones that JC Whitney sells. I got one for our 86 Corvette because the old one was sticking. Paid just over $200 for a 52mm and it has worked perfectly.
Old May 15, 2011 | 09:52 AM
Damon's Avatar
I'd agree that a 52 is as big as you'd want to go on anything remotely close to stock. The plenum opening is already 52mm behind the TB on most of the ones I've looked at. Bigger requires work on the plenum to make them match.
And, I'll just add that the Holley billet TBs were HORRIBLE when we bought one for my brother's 87 GTA project a few years back. Cables/cable brackets didn't want to fit, the stock "swing arm" style TPS they used on the earlier TPIs would scrape and hang on the side of the TB casting (there wasn't any clearance for it- we had to clearance it ourselves) and there was no positive stop to prevent the throttle plates from opening beyond 90*. In short, the stock unit was lightyears ahead in terms of quality, although the Holley looked like a million bucks.
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
lakeffect2
Aug 23, 2015 08:44 AM
justin57
Aug 20, 2015 07:05 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
