Rough idle loops?
Old May 15, 2011 | 01:46 AM
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
Rough idle loops?
My 89 gta starts and idles fine till you give it some gas, then it gets 'pissed' and idles down at 500rpm, when you give it gas it stumbles, ive tried Throttle position sensor, ignition control module, and ecm. after i messed with the egr valve it runs a little better (pretty sure i need a new egr valve.), and now the SES does show up and from what i got off it ( not too sure if i read it right but..) it showed code 13 "o2 sensor or tps, which i tried tps. Could this be the o2 sensor?
Opinions?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
