TPS adjustment fixed my rough running HSR setup...
Old May 23, 2011 | 07:37 PM
Looksthakill's Avatar
Car: 1985 Chevy Camaro Z28
Engine: 5.0 LG4
Hey Guys,
Thought I would post a recent experience I had with my 86 5.0 HSR.
After a couple of months of solid running, I started getting intermittent Service Engine Soon lights, and rough running. When I attempted to pull the error codes, I would only get "Code 12." No other error codes.
Long story short, I checked my TPS voltage, and it was LOW. Specifically, .24 volts. I set it to the recommended setting with my voltometer (0.54Volts ), and the car is now running normally.
Not sure how it came out of adjustment, but for the time being, it is running solid.
Thought I would pass my experience along. Check that TPS voltage!
FYI, I followed the procedures noted here: https://www.thirdgen.org/tpimod2
Old May 30, 2011 | 01:37 PM
Bronze85's Avatar
Re: TPS adjustment fixed my rough running HSR setup...
I agree, setting TPS and then IAC makes a world of difference. If out of spec the ecm basically assume the throttle is in a different position and adjusts from that. It should be done after base timing is set.
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
customblackbird
Aug 15, 2021 10:16 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
perZ
Aug 15, 2015 01:17 PM
