Ford injectors in TPI
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
hey everyone i need a definitive answer on this, will foxbody 5.0 mustang work with tpi with no modifications, will the connectors work, are they the same height. i know i heard ls1 injectors are shorter so i'd rather not deal with that noise.
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
Re: Ford injectors in TPI
and im using ford svo 24 pound injectors in my build also...
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
I am useing the bosch 3 design that came from a ford, they go right in, they just dont have the slot for the retaining ring that the denso injectors have. No big deal, they are held in place by the bolts on the fuel rail anyways. most people like these fuel injectors over the stock units
Transmission: Pro-built 700R4
I've had the 24 lb SVO injectors for about a decade now. Never had any issues.
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
Sanjay
Aug 12, 2015 03:41 PM
