Confused need help with runner match
Old May 28, 2011 | 09:51 PM
rongreen's Avatar
Car: 1938 Chevy 2 dr Sedan
Engine: Dart400 AFR190 TPIS ZZ409 Big Mouth
Transmission: Gearstar 700R4 level 4
Axle/Gears: Moser 12bolt-Det Trac loc 3:42
Why are the small conector tubes on the runners pluged with RTV on my after market TPI runners?
Old May 29, 2011 | 01:39 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Confused need help with runner match
'Cuz PO deleted the EGR/9th injector, most likely.
Old May 30, 2011 | 08:42 AM
rongreen's Avatar
Yes they both are not used.
Then will the old style 1986 TB and IAC breath thru the manifold and plenum with the tubes plugged. Frankly I do not clearly undersatnd the internal air flow thru the plenum. I read TB are difference for difference years. Any expaination will be appreciated.
Old May 30, 2011 | 09:59 AM
87TTops's Avatar
Car: 1987 IROC-Z
Engine: LB9
Axle/Gears: BW 2.77
The one on the driver's side is air for the cold start injector which normally is right below it on the base. The passenger side tube is for the EGR. The TB and IAC won't be affected by either of those tubes, just the cold start injector and the EGR. Are you using either?
Old May 30, 2011 | 10:55 AM
rongreen's Avatar
NO not using CS or EGR. My confusion is the triangle port on the TB and the plenum that look like they are connected to common manifold area of the EGR and CS. Can not tell looking at it but will the mismatch of the plenum and base cause idle adj. problems. Motor is not assembled yet.
Old Jun 2, 2011 | 02:24 PM
rongreen's Avatar
Is is not possible to use an early year MAF TB and plenum with a later year MAP manifold. Is that the case and if so can you modify the 85-88 TB and plenum to work with an 89-92 manifold. No cold start or EGR is used.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
rusty vango
Sep 29, 2015 02:44 PM
