86 T/A 5.0 TPI Swap with 88 T/A 5.7
Old Jun 2, 2011 | 02:10 PM
86Trans/AM's Avatar
Car: 86 T/A GTA Rims
Engine: 350 Mild cam 750 holly
Transmission: Beefed 700R4
Hello, im swapping out my 86 T/A 5.o block with a 5.7 block from an 88 T/A and i was wondering if the 5.0 TPI set up would fit on the 5.7 block that is going into the car. Would it be to small or is it the same size? Also does it matter if the injectors from the 5.0 are on the 5.7 ? Thank you.
Old Jun 2, 2011 | 02:58 PM
86Trans/AM's Avatar
Re: 86 T/A 5.0 TPI Swap with 88 T/A 5.7
Never mind i found out the answer from a post earlier posted the only questions i have now is, can i change the injectors on the 5.7 rail to the ones from the 5.o ?
Frozer!!!
Jan 19, 2024 04:55 PM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
