Tips on Manifold Install
Old Jun 19, 2011 | 07:39 AM
megtom2's Avatar
Car: 1989 Pontiac Formula 350
Engine: 350 tpi
Transmission: 700
I installed an accel high flow base a couple of months ago with poor results. Tore it back down and found water had made it's way into the cylinders. I torqued the bolts to the specs but did not use any rtv or sealer on the gaskets. I checked the manifold with a straight edge and the manifold is straight. Should I use some type of sealer this time and maybe go over the torque specs a few lbs?
Old Jun 20, 2011 | 11:04 AM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
Re: Tips on Manifold Install
I didn't use any sealer on the gaskets,(some say to do it some say don't ) But I did put a good helping of thread sealer on all the intake bolts.(I had water like you) And I wouldn't go over the torque specs. I don't have any leaks now.
You did remember to use RTV Black on the front and rear of the intake right?
Old Jun 20, 2011 | 11:12 AM
hairysox33's Avatar
You didn't mention it, but make sure you torque the manifold in sequence as well. It couldnt hurt to put a little RTV around the water passages... Just sayin'
Old Jun 20, 2011 | 11:54 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I use felpro paper gaskest and a very thin layer of TFE pipe paste around waterjackets and black permetex sensor safe RTV on the front an rear china walls..
Old Jun 20, 2011 | 12:13 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Always put alittle RTV around the water jackets and a healthy coating on the front/rear china walls, especially at the corners where they met the heads.
I used RightStuff for the entire intake gasket before with great success. Put a good bead all round each port and down the intake face between ports and it seals great. Let it set up for a few minutes before installing manifold and torquing to spec.
Always torque in proper sequence as well!
Old Jun 21, 2011 | 07:00 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
like orr89rocz said..... i always put a bead of sealant on the front and back of the block... SBC are know to leak there..... i also put a small amount around the gasket bolt holes and put thread sealant on the bolts to make sure nothing comes up through the bolts..... make sure you get the sealant thats instant (it cost more but worth it) and not the one that takes 24 hours to cure....
rocn7roc
Sep 21, 2021 02:16 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
Hello, Michael
Aug 20, 2015 03:19 PM
