will 91 mustang inectors 5.0, fit in my 1991 trans am 5.0 tpi
Old Jun 29, 2011 | 03:37 PM
collinta's Avatar
Car: 1991 trans am
Engine: 5.0l tpi
Transmission: auto
have the injectors need to know if they will work for me, and i dont know what my inj pressure is
Old Jun 29, 2011 | 03:56 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: will 91 mustang inectors 5.0, fit in my 1991 trans am 5.0 tpi
stock 305 TPI injectors are 19 LBs
Old Jun 29, 2011 | 04:18 PM
collinta's Avatar
Car: 1991 trans am
Engine: 5.0l tpi
Transmission: auto
but will they fit in
Old Jun 30, 2011 | 01:02 AM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
If you are talking about the yellowtop injectors with a black body that ford used on nearly every 5.0 from the 90s through early 2000s then yes, they go in just like stock, you can even use the retaining clips
Old Jun 30, 2011 | 04:18 AM
1989IROC-Z5.7L's Avatar
Car: 1987 Buick WE4 Regal
Engine: 3.8L IC Turbo
Transmission: 200 4R Auto O/D
Axle/Gears: 3.42 posi
I bought a set of "Blue Top 24lbs" Ford Motorsport injectors for my IROC. Worked perfect! http://www.fiveomotorsport.com/
Old Jul 1, 2011 | 12:03 AM
collinta's Avatar
Car: 1991 trans am
Engine: 5.0l tpi
Transmission: auto
what pressure are the yellow ones
Old Jul 2, 2011 | 07:02 AM
White93z34's Avatar
Engine: LB9
They are rated at 19lb at 37psi, at our 43psi they run a little more
Old Jul 2, 2011 | 08:00 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
I thought the 19's for the Mustang were orange?
Old Jul 2, 2011 | 01:02 PM
White93z34's Avatar
Engine: LB9
I'm talking about the older yellowtops that look similar to multitecs. Afik the orange bosch III injectors that newer fords use are 30lb, don't quote me on that though.
Old Jul 2, 2011 | 01:38 PM
ninetyone's Avatar
Axle/Gears: 3:42
When i was into 5.0 motors the stock 19lber's were orange and the 24's were blue.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
Exxon Limited
Aug 9, 2015 08:13 PM
