Removing The Plenum
Old Jul 6, 2011 | 04:04 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Removing The Plenum
Hey guys, I had a quick question.
I need to pull the plenum off my motor in order to change out the IAT sensor and my stupid Haynes manual makes no mention of the plenum that I can find. After I remove the throttlebody, is it as simple as removing all the plenum to runner bolts and lifting the plenum up from between the runners or must one of the runners be removed as well?
Also, I am thinking the gaskets should still be good to be re-used. They are the felpro kind with the steel inserts and have only about 15k miles on them. What would your take on this be?
Old Jul 6, 2011 | 04:20 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: Removing The Plenum
Yes, it can be done that way, but I would recommend at least loosening the bottom runner bolts otherwise you run the risk of damaging those gaskets
Old Jul 6, 2011 | 04:55 PM
Car: 1985 Z28
Thanks a bunch man! One more favor to ask, do you know where I can find the TPI bolt torque specs?
Old Jul 6, 2011 | 05:05 PM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
yeah I'd do it that way too. loosening the bottom runner bolts works great.
Old Jul 10, 2011 | 05:28 PM
norcalz28's Avatar
Snug is more than enough. Going into aluminum like that, with such a coarse thread, those bolts will be fine if just cinched down. You don't want to strip them.
Old Jul 10, 2011 | 07:07 PM
Car: 1985 Z28
I read 25 ft/lbs is the proper spec.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Nick McCardle
Sep 10, 2015 08:36 PM
