tbi cam same as tpi cam. 1991 long block
Old Jul 7, 2011 | 07:32 AM
musicfreako's Avatar
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
I have a junk long block tpi and a good tbi longblock. will the tpi setup work on top of the tbi longblock? This is a 1991 camaro z-28 305. Thanks guys...
Old Jul 7, 2011 | 09:46 AM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Re: tbi cam same as tpi cam. 1991 long block
the tbi cam is smaller then either tpi cam. itll fit but will not impress. torque would be over powering tho.
Old Jul 7, 2011 | 09:59 AM
I'm building a new 305 for my Camaro using heads, cam, tpi setup from original, but using a 91 305 truck long block originally equip tbi. What I need to know is will my roller cam fit in this block. I know I have to swap over those roller lifter retainers.
Old Jul 7, 2011 | 10:12 AM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Originally Posted by musicfreako
... will my roller cam fit in this block....
Yes. You may need to have the bosses for the roller cam spyder machined IF they aren't machined now.
jhawkeye
May 25, 2022 06:33 PM
camaro71633
Sep 1, 2015 10:24 AM
Sanjay
Aug 12, 2015 03:41 PM
Fronzizzle
Aug 9, 2015 01:15 PM
anesthes
Aug 8, 2015 09:37 PM
