Injector voltage problem, please help
Old Jul 8, 2011 | 04:45 PM
TransMan350's Avatar
So i just swapped out my flexplate the other day and when I put everything back together my car wont start!
It was starting fine before I swapped the plate. I have spark and I'm getting fuel to the rails. I started testing voltages on the injector plugs and couldnt get a reading on any of them. I then went back and checked voltage at the injector fuses and could not get a reading on either of them.
What could have happened while changing the flexplate to cause this problem?
Is there any small thing that is able to stop power from reaching the injector fuses? I tested the pick up coil and that tests fine
Also my car does not have VATS
Old Jul 10, 2011 | 07:44 PM
Re: Injector voltage problem, please help
hmmm.. well after a full day of playing around with all components involved in the injector circuit and lots of testing the problem is gone.
Not sure what I changed exactly, must have been a loose connection somewhere.
Old Jul 11, 2011 | 08:51 PM
ozlow's Avatar
i'm putting a 92 camaro tpi on my 82 vette.i used a custom made harness.and comp.with the vat taken out.it don't want to run.it idles rough by dieseling' if you start to drive itseems ok but when you get down on it it just nosedives' ichecked the power going to the injectors'. when i checked the power to the inj.both sides were hot' i no each side of the inj has a+ an a- please what's my problem?
mdtoren
Aug 23, 2015 12:52 PM
justin57
Aug 20, 2015 07:05 PM
ezobens
Aug 19, 2015 10:29 PM
Bryan F
Aug 18, 2015 02:28 PM
