Have you ever seen this...
Old Jul 14, 2011 | 01:18 PM
GoodApollo's Avatar
Car: 1991 Z28
Engine: 5.7L 350 TPI
Transmission: A4
Ok so I've just about finished putting back together the throttle body off my 91 Z28 5.7 350 TPI (im pretty new to this stuff) and I can't seem to find this one gasket anywhere, it goes between the TB and the plate that says Tuned Port Injection on the top of the TB
does anyone know where i might find such a gasket?
(EDIT: Or if i even need the gasket?)
Old Jul 14, 2011 | 03:56 PM
Abubaca's Avatar
Re: Have you ever seen this...
You could probably just use RTV.... I'd imagine using NOTHING would almost be ok, although I'm not suggesting you do that.
Old Jul 14, 2011 | 03:58 PM
Abubaca's Avatar
...or...
http://cgi.ebay.com/ebaymotors/Camar...Q5fAccessories
Old Jul 14, 2011 | 04:39 PM
Elthesh's Avatar
Car: 1991 Pontiac Trans Am
That gasket comes in many gasket sets. You can just look up Ac Delco part number 40709 which contains the gasket for the top plate and the water plate on the underside. If you can use a razor blade, you can also just buy a roll of gasket material, cut a piece out, trace with a pen or whatever and cut it out. The gasket set is the easier way though. Also, part number 2009 for Standard Motor products is another set with that gasket.
Old Jul 15, 2011 | 01:28 PM
GoodApollo's Avatar
Car: 1991 Z28
Transmission: A4
Thanks sooo much guys, even the two auto parts stores where I live couldn't find them.
92firebirdguy
Sep 1, 2016 07:53 AM
luvofjah
Sep 26, 2015 08:28 PM
Blue419
Sep 10, 2015 01:03 PM
Thaney9
Aug 7, 2015 08:25 PM
CD MaroMan 91
Mar 13, 2002 04:15 PM
