Cam timing -4,0,+4????? Stock LB9
Old Jul 22, 2011 | 09:11 PM
85 Frankenstein's Avatar
Car: 1985 Camaro Z28
Engine: 1988 305 TPI
Transmission: 1993 T-56
Axle/Gears: 3.08
Hello, I have a 1988 305 TPI engine with about 80k on the clock. I am in the middle of replacing the head gaskets and I figured while I am this far into the engine it would be a good idea to replace the timing chain and gears. I bought a cloyes double roller 9-3145. I also have a set of comp cams 1.6:1 full roller rockers to install if this makes a difference. From the research I have done I can't come to a definitive answer about how to set the cam timing. stock or four degrees either way. I have a t56 behind engine with 3.08 gears. I am running stock exhaust manifolds and exhaust, MSD coil and distributor. I cruise 70 mph at 1750 rpms. I rarely take the engine above four grand and want all of the drivability I currently have. Any advice is greatly appreciated. Thanks
Old Jul 22, 2011 | 09:17 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
Re: Cam timing -4,0,+4????? Stock LB9
stock cam... advance
Old Jul 22, 2011 | 09:28 PM
Guest
Guest
Posts: n/a
Agreed. Especially T56 / 3.08:1...good luck with that, BTW. Only the Viper pulls that gearing. Unless you didn't get the good 0.50:1 sixth.
Old Jul 22, 2011 | 09:29 PM
Axle/Gears: 3.08
Is there any negative side effects from setting the cam timing advance four degrees? Issues with computer or anything else? From what I understand this should increase low end torque, correct?
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
camaro71633
Sep 1, 2015 10:24 AM
happyhapka
Aug 15, 2015 04:42 PM
Thirim
Aug 9, 2015 06:19 PM
