injector damage by having fuel pressure very high??
Old Jul 29, 2011 | 09:51 AM
jaygt's Avatar
Car: 80,81,85, trans am
Engine: 4.9,301turbo,350
Transmission: all auto
Axle/Gears: 308,342,308
i set my fuel pressure with vacume hose connected. big mistake. so it reads 49 psi with vacume hose on.
1989 l98
im on my way to set with hose off and connector plugged. or is it hose plugged or both??
my car does not start sometimes just revs for one second and dies.
could my high fuel pressure cause this im using bosch 111
could i have caused any damage to the injectors?
Old Jul 29, 2011 | 10:01 AM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: injector damage by having fuel pressure very high??
no worries 49# is nothing.... you can crank them up to 65 or a lil more with no damage
you should be @ 45# and yes while setting pressure unplug vacuum from the regulator & plug the new leak
Old Jul 29, 2011 | 10:09 AM
JustCruzin's Avatar
Bosch D3's are good to 6-7 Bar 72psi is 5 Bar so I think you have plenty of room for error
specialized
Jun 18, 2022 09:26 AM
9192camaro
16
Feb 3, 2019 12:21 AM
Brcharrelson
Aug 26, 2015 07:47 PM
R3500
Aug 17, 2015 12:16 PM
Kaweh
Aug 9, 2015 02:54 PM
