New BBK AFPR. Now weak fuel pressure?
Old Aug 1, 2011 | 11:32 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Ok ok before i get "adjust the damn thing!!" Let me tell you what's up.
I had a MAJOR issue with the stock regulator taking a dump. It was spitting fuel into my upper plenum and spewed out when I disconnected the vacuum line from the plenum. It came apart in three pieces when I removed it if that tells you anything,lol. Anyways, now it's gotten even harder to crank, sometimes I have to give it gas like an old carbed car before it will actually start. After it starts it runs like a champ. I adjusted the regulator with the vacuum line disconnected and it reads a solid 45 psi. When I plug the vacuum back in and running it reads about 35-37 psi and it seems a little "jumpy". When I give it throttle it will "rev" up to 45 then goes back to 35-37 psi. I'm kind of at a loss here. Does this mean I have a weak pump or do I need to adujst the regulator some more? Any help with this would be awesome.
Old Nov 6, 2011 | 10:33 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Re: New BBK AFPR. Now weak fuel pressure?
What you have described, 35-37 with vac 45 w/o vac, sounds fine. The regulator is supposed to drop fuel pressure at high vacuum (idle and cruise) conditions and bump the pressure at low vacuum (high throttle) conditions.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
