What is this supposed to connect to.
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
I don't know what this vacuum port is supposed to connect to. The old TB that I pulled off it didn't have this port. I can't tell for sure from some the diagrams Ive been looking at. Its just in front of the port the T's off the vacuum canister and the EGR. Thank You
Engine: 4++,350 & 305 CIs
Re: What is this supposed to connect to.
The hard line you have thats open goes to the Tbody where the rubber vac line is now. the hard line is missing its 90deg elbow that connects the 2 which is prolly y someone just ran a new line..
Car: 1991 Z28 1LE
Engine: LB9 305
Transmission: Borg Warner T-5
Axle/Gears: GM 7.5 3.42 Posi
That probably is the supply to the EGR solenoid. It should be connected to primary vacuum.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
