Car Craft 1991 Article INJECTION PERFECTION
Old Nov 7, 2011 | 06:56 PM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
Now that I have a TPI car I decided to go thorugh some of my old magazines looking for articles for upgrades. This is from Car Craft 1991 and it might help some and some might say, this is crazy but I like pictures of some of these "upgrades" guys post on here. I am new to the TPI thinkg and truly not even sure what all the part names are for the setup but I WILL know soon.
Old Nov 7, 2011 | 07:26 PM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Re: Car Craft 1991 Article INJECTION PERFECTION
That's interesting.
Never heard of anyone porting the TPI Throttle Body and putting in larger butterfly valves.
Anyone here tried this?
Old Nov 7, 2011 | 07:36 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Originally Posted by peterc005
That's interesting.
TONS of stock TB's are ported out to 52mm . search on ebay you should find a handfull.
Old Nov 7, 2011 | 07:41 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
wow, lots of guy's under rocks for 20 years
lingenfelter, tpis, arizona speed and marine, street and performance, ebay
Old Nov 8, 2011 | 08:06 PM
Drew's Avatar
Sometimes it's best to ignore the dark ages of EFI performance.
Old Nov 8, 2011 | 08:25 PM
Engine: Lb9
Transmission: M20
Old Nov 8, 2011 | 08:32 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Yup, best to ignore extra power, until your competition beats you.
Did this to mine in the early 90s
Old Nov 8, 2011 | 09:21 PM
Drew's Avatar
A larger throttlebody does virtually nothing on TPI cars, because it's not the choke point in the stock system.
Old Nov 8, 2011 | 09:31 PM
TTOP350's Avatar
key words.. stock system
Old Nov 8, 2011 | 09:49 PM
Engine: Lb9
Transmission: M20
intake manifold choker !!
Old Nov 8, 2011 | 10:24 PM
peterc005's Avatar
Transmission: T700
What is the choke point then?
Do you mean the runners or manifold ports?
Old Nov 8, 2011 | 10:35 PM
Drew's Avatar
Did anyone else read the article? Supposedly a bored throttle body, computer chip, and K&N filters freed up 15hp and allowed the engine to pull strong to 5500rpm, all for less than $500. They're trying to sell these mods, when it's well known that bored throttle bodies and commercial chips are a waste of money. A simple throttle body change is not going to change the tuned RPM range of the intake.
The article is just as bad as all the free/cheap mods that have been discussed ad nauseum. It's not completely useless information, but it's a waste of time and money for most people looking for a bit more power.
It's just dated info, and not all that applicable in the modern world. Go ahead and buy a cheap generic chip, an expensive big bore throttle body, and some K&Ns. Dyno it before and after and report back if you get anywhere close to a 15hp improvement at the wheels. Run it down the track before and after, let us know if the car actually traps any faster... Any improvement is going to be marginal to the point of being barely recognizable.
Old Nov 8, 2011 | 10:38 PM
Drew's Avatar
Everything bolted behind the throttlebody is about tied... Base and runners are going to be a problem before the plenum or TB.
specialized
Jun 18, 2022 09:26 AM
jhawkeye
May 25, 2022 06:33 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
kyleb24
Aug 15, 2015 08:24 AM
