85 TPI Injectors Reliable?
Old Aug 7, 2011 | 04:29 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
As i'm ohm checking my injectors because I have a rough idle, Ive gotten exactly 16.5 on the 4 injectors ive checked so far.
Are the injectors they used in the 85 LB9 more reliable than the Multec era? Should I just clean these and see what happens? I have 101k on the car if it matters...
Old Aug 7, 2011 | 08:19 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: 85 TPI Injectors Reliable?
The ohm reading on the injector doesn't tell you if the injector is working correctly. Just that it's working(maybe). 101k on a set of 1985 injectors is pretty good. You've definitely got your money's worth out of them. I can't say they are the cause of your rough idle, however, IMO you are over due for a set of injectors.
Old Aug 7, 2011 | 08:40 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Im going to go thru and do plugs wires cap and rotor since I havent done them yet, then if its still acting the same (which om hoping rough idle is cured by then) I will look into a set of injectors.
Thanks for your input.
Old Aug 7, 2011 | 09:03 PM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
You need to upgrade to Bosh III injectors...They are way better!!!
F.I.C. has them. 19lbs for a 305 .
Steve78LT
Feb 24, 2016 12:15 AM
Brcharrelson
Aug 26, 2015 07:47 PM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
ezobens
Aug 19, 2015 10:29 PM
Sanjay
Aug 12, 2015 03:41 PM
