Code 42 and 43
Old Aug 7, 2011 | 11:59 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Code 42 and 43
I have a 91 GTA.
I am getting codes 42 and 43.
So far I have checked sensors to be working
oxygen sensor
MAP sensor
Some wierd problems I am having is:
-when I hook my laptop to the car it shows that the knock sensor is retarding 20 degrees, then I unhook the knock sensor and it still pulls 20 degrees out
-I pulled the plugs out, cylinders 1-4 are showing lean, 5-8 are showing rich.
So where is my ESC on a '91 GTA?
Could my problem be a ignition module?
BTW, the problem happened when I was racing and spraying nitrous too.
But I did run the car for a whole season with no codes.
Any help?
Old Aug 9, 2011 | 12:40 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Re: Code 42 and 43
I am gonna try a new knock sensor tonight and see if that fixes it
Old Aug 10, 2011 | 01:48 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Code 42 and 43
don't forget to clear the codes by disconnecting the neg. battery cable for a min or so.
Old Aug 10, 2011 | 10:32 PM
neitzelm's Avatar
Car: 1985 Z28 Camaro
Axle/Gears: Posi 4.10
Re: Code 42 and 43
If the knock sensor is working properly, you might have a bad ESC Module. I just replaced mine and that seemed to fix my problem. If the ESC is ok, it could be the connector on the ECM (Most likely not)
If you have a lot of mods to your engine like a mild cam or headers, you could be getting false knock. I'd suggest throwing a 3.9k resistor in place of your knock sensor. I just have the wire hooked up straight to my negative on the battery.
Old Aug 11, 2011 | 12:47 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Re: Code 42 and 43
Update!
The new knock sensor fixed the problem
Old Aug 11, 2011 | 12:52 PM
neitzelm's Avatar
Re: Code 42 and 43
Originally Posted by LB9GTA
Update!
Glad to hear it. Good thing it was an easy fix for you.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
