1990 Corvette 5.7 TPI Chasing a DTC32
Old Aug 12, 2011 | 01:25 PM
cobravette's Avatar
I wonder if anyone can help with where on a 1990 Corvette with the 5.7 TPI engine the EGR Temp Diagnostic Switch is located? I'm chasing the infamous Code 32. I've changed the EGR Solenoid but still get the code after driving for a while. I drove with a vacuum gauge T'd in just before the EGR valve and did not see any change in vacuum while driving at 65 MPH. Vacuum held at 10" when the code came in. I have a new EGR valve that I can change out but I'm not so sure it's bad. Testing it appears to be successful. I've seen the test documents with the flow charts and diagrams which show the switch. I would sure like to test it if I could find it. Is this an item that they eliminated on the 1990 models?
I would greatly appreciate any help
Old Aug 12, 2011 | 01:54 PM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
Re: 1990 Corvette 5.7 TPI Chasing a DTC32
I don't think a 90' corvette would have it. if you do it will be on the side of your EGR valve just a one wire connector.
Old Aug 12, 2011 | 02:08 PM
cobravette's Avatar
Any ideas on solving this DTC32 issue?
Thanks!
Old Aug 12, 2011 | 02:18 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes the EGR temp sensor was not used on the 90-92 speed density TPI setups.
For fixes, check the solenoid, the vacuum lines, and the EGR valve itself.
Frozer!!!
Jan 19, 2024 04:55 PM
diana227vegas
Jul 8, 2016 12:27 AM
gta90
Sep 15, 2015 04:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
Sanjay
Aug 12, 2015 03:41 PM
