New Intake
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
New Intake
The Stealth-Ram (vortech) just showed up, i went with the polished unit, waiting on the Vortech aluminum heads this week. The Paxton is out being refreshed, I can start putting this together if I ever get done sanding and preping the body. I also went with new 30lb Bosch injectors and the Holley fuel rails with the adjustable fuel pressure regulator.
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
Re: New Intake
Looks nice, are you sticking with the stock ECU and just getting a new chip burned or did you go with Holley's ECU?
Re: New Intake
Once I get the entire car back together (see my thread in restoration) I will take the car to be dyno tuned, I will have them burn a new chip. I am hoping the speed density will learn a little as the car runs, if not I will tow it to the dyno shop so I dont damage anything. I really did not look into the Holley ECM, do you know anything about them, good or bad? I am trying to decide what Size TB to go with and what brand next.
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
