main harness routing and 3 wires/connectors need locations
Old Aug 17, 2011 | 09:48 PM
resop27's Avatar
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
well this part is really overwhelming I'm used to bmws with a nice and simple clean harness this camaro has so much I'm not sure how it was routed I know it goes through the fender and into the cabin but after that where does it go close to the heater box?
anyone have any larger engine bay pictures? where you can see the mainharness layout.
also have three connectors I'm not sure where they go.
this on is near the ground for the back of the block
this one is right next to the heater box
and this one is about 3 feet long
Old Aug 18, 2011 | 06:53 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: main harness routing and 3 wires/connectors need locations
number 2 is the power plug for the blower assembly IIRC, just did a non ac swap, got real familiar with that area of the harness lol and that third one i just cut....no harm....yet lol
Old Aug 20, 2011 | 03:01 PM
resop27's Avatar
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
well got one figured out. anyone else know?
Old Aug 20, 2011 | 03:06 PM
Pocket's Avatar
Car: 91 Trans Am
Nope
Pic #1, tan and blk wires are for the IAT sensor under the TPI plenum. There is a short adapter harness going to a CTS sensor. You would do well to mvoe the IAT to the intake or swap the brass CTS thing for a plastic cage style IAT from a GMC Cyclone. Plastic wont heatsoak as badly as mercury filled brass so the ECM will have a better clue what your actually IAT is and adjust fueling accordingly
Grd ring is right, bolt it to the rear of the drivers cyl head. Any hole will do. Should be another ring or two for the pass cyl head
Tan/blk, wht, blk/red, ppl/wht 4 pin connector goes to the distributor. Theres another short adapter harness than runs from the second dist plug to the coil
Pic #2, fuel pump relay test lead. Add 12v to that terminal and your pump will turn on regardless of what the rest of the car is doing. Nothing connects to it, use for diagnostics only
The tan/blk single pin connector on top of the HVAC box is the DST connector. Unplug this when setting base timing then reconnect
Pic #3, orn, hood light. You can see the inline connector in pic #2 that this goes to
Caspar
Jun 19, 2016 11:19 PM
fbirdroller
Sep 2, 2015 10:27 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Keith5
Aug 27, 2015 04:37 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
