MAP distance
Old Aug 20, 2011 | 02:18 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
MAP distance
i recently installed hte EZ efi on my 89 FORMULA and im using a 90-92 plenum to correctly locat the MAP mostly for clean appearance reasons but where its located is in the way of me installing a fuel press gauge and im thinking about moving it to the lip of the cowl.
how far can the MAP be moved away from its stock location and not cause issues?
Old Aug 20, 2011 | 02:50 PM
Pocket's Avatar
Car: 91 Trans Am
Re: MAP distance
Can mount it in the trunk if you wanted to
It measures change in vacuum, it does not consume it, so put it wherever is convenient and dont worry about it
Old Aug 20, 2011 | 03:09 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Re: MAP distance
thanx pocket, thats what i was hoping for. to the cowl it goes!!
AUZ28
Oct 3, 2015 06:28 PM
aaron7
Sep 30, 2015 09:15 AM
tuningnewb
Sep 23, 2015 07:06 PM
ULTM8Z
Sep 16, 2015 09:15 AM
