104224 crane cam Question
Old Aug 18, 2011 | 10:02 PM
2010linkin's Avatar
Car: 1989 Trans am GTA
Engine: 5.7 TPI
Axle/Gears: Borg Warner 3.27
I was just wonering if i installed this powermax cam on my 89' 350 Trans am GTA with a 1.6 roller rocker, will there be any piston to valve clearance issues??? Or will it be better to just stick with a 1.5 roller rocker??? The bottom end is competely stock.
Old Aug 19, 2011 | 04:51 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
Re: 104224 crane cam Question
ran that cam a few years ago in my old l98 block.... with stock heads with no work done to them....just stick with 1.5 rockers... stock heads take about .470 and if i remember correctly the lift on that cam is .452 .465
that cam barely clears with 1.5 rockers..... switching to 1.6 rockers will cause a world of trouble...
Old Aug 19, 2011 | 06:44 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i run that cam in my 305 with 1.6 rockers, my valve springs support it though.
Old Aug 19, 2011 | 10:21 PM
2010linkin's Avatar
Engine: 5.7 TPI
ok thanks for your input 88fastgta. i'll stick with the 1.5 roller rockers.
Old Aug 21, 2011 | 11:15 AM
2010linkin's Avatar
Engine: 5.7 TPI
Do you still have that cam for sale??
Old Aug 21, 2011 | 05:16 PM
88fastgta's Avatar
sorry i sold that cam about three years ago...
camaro71633
Sep 1, 2015 10:24 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
